Topic: KR 16v Strange engine noise (Read 784 times) previous topic - next topic
Hi
My 16v has developed a strange screeching noise. Immediate thoughts were the distributor as it sounds like a rotational noise coming from the gearbox side of the engine, topside. I have just fitted a newly reconditioned Bosch dizzy and the noise is still there (albeit it now idles a lot smoother so one improvement!)
Small backstory on the engine: Block and Head bought s/hand, both done a small number of hours running since recon prior to my purchase. Head is a Robert Cox polished & ported and block is standard 1.8. It has piper 270 cams with an adjustable vernier on the inlet cam. Done approx 2000 miles since install with zero issues until now.
A link to video showing the noise:
https://www.youtube.com/watch?v=nFw5DUmNpzs
It only starts doing it when the engine is hot and has no effect on how it performs/drives.
Any thoughts?
Thank you. :)
Re: KR 16v Strange engine noise
That's definitely coming from the gearbox end? It sounds just like an alternator with a failed bearing would do.
You could pop the auxiliary belts off and run it for a couple of seconds, see if that changes anything.
But obviously, don't leave it running, as the water pump won't be!
One other thing I could suggest is to use a long screwdriver like a stethoscope. Put it next to your ear and then on to various parts of the engine, to see if you can determine exactly where it is.
Thanks for your reply.
Yes I have tried the old screwdriver trick. It seems pretty loud if you put it on the cam cover, dizzy end.
The alternator was a new unit fitted when the engine was built up. I may try running it without the belts momentarily just to rule it out. The noise is slightly 'behind' the engine revs. Do you think a vacuum/air leak could make the noise?
Sounds like a vacuum leak kind of noise to me.
If it only does it when it's hot could it be water related? or a bearing that running dry?
