Topic: Heat Sheild (Read 476 times) previous topic - next topic
Heat Sheild
Hi all, i have two silver heat shields, i know on hooks over the windscreen panel and sits in the two clips on the brake line fixings, where dose the other more flexible on go, its about the same size.? cheers Phil
Re: Heat Sheild
Is yours a 16v?
I'm an 8v so not that up on those... hopefully someone will confirm (or not) that they had 2 x engine heat shields whereas the 8v only has the one.
Sounds like you've the upper one and missing the lower (same as 8v's?) as pictured below (No. 4) -
Link - 7Zap
7Zap's not infallible, so always double check before commiting, but I find it an excellent resource and easy to navigate.
Re: Heat Sheild
Yes sorry 1990 16V
