Topic: mfa (Read 1347 times) previous topic - next topic
mfa
When I bought the car the mfa did not work. I have investigated and believe the display screen is shot I have sourced a replacement screen. Further to that I found the vacuum pipe disconnected I have not tried to connect it as the pipe looks to small a diameter the question is is there an adaptor between the two? The car is a 1990 with ce2 electrics.
Re: mfa
You should have a rubber hose on the end or the more rigid plastic hose. Is yours missing?
Re: mfa
Thanks the pipe does appear to be soft rubber just thought the diameter looked small compared to the ribbed mfa connection.
Re: mfa
Here's mine
Re: mfa
that's the geezer. annoyingly short
Just disconnect it in the engine bay (near the nrv) and then push the excess pipe back through the grommet.
All the length you need then ;)
