Topic: Heater Matrix Pipes (Read 550 times) previous topic - next topic
Heater Matrix Pipes
Anyone know how the pipes are plumed? I have a metal manifold inline in mine but it was not fitted in the car when i got it (engine had been removed) so I have no idea where it goes, looks like its some some of valve to aid air bleeds? Phil
Re: Heater Matrix Pipes
That sounds like the heater mod fitted by VW when heater matrix's were failing cant remember whether it was fitted on the inlet or outlet. I believe some have demoded and removed it.
Yep sounds like the fix for the original heater matrix problem. Do you want to keep it 'original' ?
I've replaced with MK3 hoses. Looks a bit neater.
The B&B guys on ebay have them.
OK thanks, all the pipes I was supplied with are new (Meyle) and they seem to fit perfectly without this 'thing', the matrix is MK3 and new so it should be fine, thanks all
