Topic: No heat from heater (Read 4626 times) previous topic - next topic
No heat from heater
Hi Everyone,
I have a '91 1.6 Driver that I got in July. I've just discovered no heat comes from the heater (first time using it!). Any ideas why?
Thanks.
Re: No heat from heater
I think its a blocked heater matrix.
Are the water pipes hot that go through the bulkhead? If not you may need to get rid of an airlock.
If that is the case then squeezing the various water hoses whilst the engine is idling should do the biz.
Thanks for the info'. Absolutely bucketing down here, and I don't have a garage. I'll give that a go tomorrow and see whats, what.
Maybe not blocked matrix, more likely if you still have the bypass valve fitted it will be that blocked. Either way probably wise to replace the matrix so it doesn’t pop then remove the bypass, no longer needed with a new matrix and replace the 2 heater hoses that will have been cut for the bypass with mk3 ones available new.
The bypass is an 90s recall that vw did as a quick fix to poorly designed matrix that would burst and spray occupants feet with boiling hot coolant.
Matrix design was changed so all new ones shouldn’t need the bypass. But make sure you get a reputable brand.
I hope for your sake it isn't the heater matrix. But if it is you will learn all about what is behind the dashboard.
It's raining here too. Just been under the Caddy on the drive. That wonderful sensation of rain dripping on my bottom half whilst trying to replace the big ends.
Where did summer go!
Recent GOV.UK survey cited 91% of people are satisfied with their lives.
The other 9 percent own a Volkswagen.
I would get out more but it’s raining cats and dogs here as well.
I've half dismantled the dashboard, and the foam is all gone from inside the heater box. Should be dry tomorrow so going to try and cover the adjusters with heat proof aluminium tape.
Thanks for all the advise.
Will keep you updated... ;D
So...
There was no foam on the heat box adjusters, so I've covered them with heat proof tape and cleaned out all the foam bits.
I ran the engine while doing this, and when I first put the heater on, the air was hot for maybe 20-30 seconds.
I've just used the car for 30 minutes and the heater is warmer than before, but still not really warm.
Yesterday I checked that all the pipes to the heat matrix were hot (they are), ran the car with the expansion tank lid off and massaged various hoses while the engine was running. I've recently had the thermostat housing replaced and since then the temperature gauge is significantly lower/cooler. I'm also fairly sure the heater was warmer before the housing was replaced, but I've not really used the heater since having the car.
Any ideas?
Thanks.
Is the temp gauge in the middle when fully warm?
Re replacing the foam. Just clarify which foam you have replaced. It's the foam on the flaps in the heater box that disintegrates and needs replacing.
Hi, yes it's the foam on the flaps in the heater box I've replaced.
No, the temperature guide never moves above 1/4 hot. Before the thermostat housing was replaced it would go above half when in traffic, but since the repair it doesn't go anywhere near that high. Not sure if the garage replaced the thermostat when they did the housing, or if the coolant system was flushed. I will check when they open tomorrow, but I'm thinking maybe the thermostat is stuck open and/or it needs a coolant flush (or 3!).
I had this issue on a previous car any selection of fan speed above one and the air would start warm but quickly blow cold even though the engine temperature was normal. I was convinced it was a blocked matrix. I never cured the problem even following flushing and loads of fiddling. note I did not replace the matrix.
When the engine is fully warm do the water pipes get very hot to touch? The bottom rad pipe from the thermostat should be very hot to touch proving water is getting to the radiator. Obviously be careful putting your hand near the drive belt (might only be an issue if you have PAS).
It also might be worth flushing water through sections of the cooling system (hose pipe) to ensure no blockages before flushing with distilled water and re-filling.
Have just checked, all radiator hoses get very hot. Checked paperwork from garage and it wasn't the thermostat housing that was replaced it was a housing elsewhere, so I'm still thinking it could be the thermostat stuck open?
Am currently running a coolant flush through to see if this does anything, can't say I fancy flushing things with the hose, I can see that going very wrong :o
