Topic: No heat from heater (Read 4627 times) previous topic - next topic
Re: No heat from heater
Reply #30
Well, I’ve got around to changing the matrix and the heater is now tropical 🌴.
Bit of a fiddly job but inexpensive, as the matrix was only £30 and available from my local Eurocar Parts.
Thanks for all the advice and knowledge, you have all been invaluable.
Reply #31
Excellent and without taking the dash out?
Reply #32
Removed the under dash shelves from both sides and the centre console. Then the 3 bolts under the bonnet and is sort of dropped out (with a bid of persuasion). I thought lining it up to put it back would be the hardest bit, but it all lined up great. I only intended to start removing some of the interior ready to do it at the weekend. It turned out to be much easier than I expected! Having had lots of advise beforehand was really helpful though. :)
Reply #33
Fair play to you, well done... we'll have you stripping the engine down soon!
Reply #34
I hate doing the heater matrix, doesn't help with wide shoulders, when I did one on an 86 KJet the bloody nuts on the bulkhead were rusted solid, took ages with a hacksaw cutting them off with lots of swearing!!!
