Topic: Mk3 donor car (Read 11958 times) previous topic - next topic
Re: Mk3 donor car
Found a mk4 cabrio with a AWG engine code that similar to the AGG?
Re: Mk3 donor car
That looks like the cross flow engine going by couple pics online.
It may not matter if you plan on using the MK2 head / injections system. Or you could transplant the complete setup.
Re: Mk3 donor car
Most of the guides are done with the agg, but expect it will be similar.
And the cabby still uses the same ce2 fusebox
Re: Mk3 donor car
When I was researching this I found that the MK4 was  a significant more hassle than MK3 to transplant. But, as above, if it is a cabrio then it should be the same as the MK3.
Phil
All sorts of stuff done, lots more to do!
Re: Mk3 donor car
Have a look here, there are a lot of questions answered which will be applicable to you.
Phil
Re: Mk3 donor car
Profile*
Re: Mk3 donor car
Does anyone know(in sure you do!) If the mk3 tdi has same subframe and brakes and stuff.. cheers
Re: Mk3 donor car
Reply #25 –
Hey guys been waiting far a cheap 3.5 to come up.. but wondering about a mk2 ibiza gti cupra.. is that any good as a donor?
Re: Mk3 donor car
Reply #27 –
That's the abf one I believe
Re: Mk3 donor car
Reply #28 –
Hey quick question if I have r rear beam from a mk3 that has dins on it... I'd it just a matter of getting mk3 hubs and disc setup?
Re: Mk3 donor car
Reply #29 –
Presume you mean drums, I don't think the rear beam swaps to a MK2, that aside you will probably missing the bias valve.
