I wouldn't trust myself with a resurfaced drive! I could almost guarantee there would be a fluid leak!
Ours is tarmac and has the tell-tale traces of oil drips from under the car engines plus the axle stand impressions - need to get some with flat feet !
Given a year without any leaks the weather cleans it up nicely
Just taking another looksee at your door membrane.
I've bought those milky clear rubble bags and cut them so that they fold out to a big enough size to cover the whole door. I've also fed the cabling up through the membrane rather than down. ie any water then travels down the wire and stays in the door rather than down the cable and behind the door card...if you get what I mean? i always wondered why our house aerial cable had a loop in it feeding up into the house...that's the reason.
