Topic: Tried and tested methods of getting stubborn nuts off (Read 2989 times) previous topic - next topic
Re: Tried and tested methods of getting stubborn nuts off
Reply #30
@PWardy I bought this bit of kit that makes supporting items easier in the press - well worth it
Did you get any instructions?  Any idea what that plate is on either side of the base each with three screws?
Reply #31
No instructions either and that plate confused me as well - seems to serve no purpose
Reply #32
Presume it's so it could be bolted/mounted to something
Reply #33
The only thing I came up with is turn them over and position them front and rear on the press. The jig can’t easily then fall off forwards and back or inside.
Reply #34
I’m coming to the conclusion they are setup as I suggested above but are a safety feature. If the jig is not setup correctly or a support fails the gig could be shot out of the press unless those plates are positioned to retain it
