Topic: Smoking engine (Read 3196 times) previous topic - next topic
Re: Smoking engine
Thanks :) coolant flange on order :)
Re: Smoking engine
Is it coming out of the oil pressure switch?
. Honestly no idea, or more to the point; don’t know where that is lol
That’s the thing above the coolant flange, with the rubber cover and wire coming from it. Pull back the cover you’ll see and electrical connection. The switch has a nut shaped base. It’s basically a bolt with a sensor in it.
Re: Smoking engine
Have you established it's a coolant or oil leak yet?
The oil pressure switch is to the left of the circle you've drawn with the wire attached.
Sorry didn't see Eddypeck reply.
Re: Smoking engine
Reply #18
Having another look at it today.
Coolant flange fitted no more leaks.
Engine turns over, no smoke (yet) but battery needs a good charge, as not firing the engine.
I’ll try and get a picture today, as the fuel filter doesn’t look like it’s filling!
So, battery will be charged today fully, then we can see what’s what.
Thanks to Mk2 Spares for getting the parts here so quickly.
Re: Smoking engine
Reply #19
How'd you get on with a full battery?
Re: Smoking engine
Reply #21
Choke cable?
Does it have a Weber on it then?
Re: Smoking engine
Reply #23
Pierburg
Re: Smoking engine
Reply #25
That's odd Pierburg carbs are usually auto choke.
Though that might have just been the two Drivers I had.
Re: Smoking engine
Reply #26
I thought the same, wonderedt if it was a different modelbof pierbirg carb though according to Google there is a manual choke conversion available
Re: Smoking engine
Reply #27
Hmm I have no idea! Will have to dig around.
