Topic: KR 16V Cokdstart Injector (Read 566 times) previous topic - next topic
Hi All
My cold start injector is not working, the injector itself is fine.
I have BV in cranking on T2 of the cold start injector N17 when cranking the engine, There is no earth which is supplied by the thermo tme switch F27. I have replaced F26 with a brand new genuine switch but still no earth. I have checked T1/W on F26 which should be earth when the engine id cols and it has 15.9 mega ohms to earth. the body of F26 is crewed int the side of the head and has a good earth. Also T2/G of F26 should be fed with BV on cranking but it is not. I am using the following wiring diagrams:
 https://clubgti.com/forums/index.php?threads/kr-16v-k-jet-ce1-ce2-engine-control-wiring-scans-corrado-golf-2-19-1g-passat-31.277245/
Any ideas please?
Phil
Re: KR 16V Cokdstart Injector
Sorry that should have read replaced F27.
