Topic: idle gets higher (Read 574 times) previous topic - next topic
idle gets higher
right after starting the automatic drive mk2,
the idle speed is about ok, maybe a bit ruff.
after some driving it gets much higher.
when is switch to neutral on traffic lights and later back,
it gives it quite a shock. therefore this especially matters.
but maybe i should not switch to neutral on traffic lights anyway ?
it is just that the motor has to work harder, then.
where to adjust the idle speed ? is there a manual about it ?
one may feel free to ask, if additional info is necessary.
