Topic: Hand brake tell tell light issues  (Read 920 times) previous topic - next topic
An issue has started where when the handbrake is off, the light flickers while driving.
It could be just a loose connection at the switch but my worse fear is the hand brake at the callipers is not being fully released, making the cable go slack and preventing the lever to be fully clear of the switch.
Before I start pulling carpets or stripping down the rear brakes just thought I’d ask is anyone else has experienced similar?
Re: Hand brake tell tell light issues
Go check your brake fluid level, that light will come on for low level too.
The switch is on the bottom of the handle, even with no cables, it'll still turn the light off.
Ahh bingo, now a feel very stupid. It’s something I know but completely wasn’t thinking along those lines.
No worries mate, sometimes you can't see the wood for the trees!
30+ year old car, always assuming the worst and overlooking the obvious   :D .
Tempted to delete this thread to avoid embarrassment, but then again the point of leaving it is someone else might learn from it. But if you so see me ask about a broken washer pump before I check the fluid then I deserve to have my keys taken off me!
