Topic: Fitting L/H Rear Inner Door Scraper (5-door) (Read 604 times) previous topic - next topic
This needs replacing and I've sourced a replacement via eBay.
Does anyone have any experience of fitting one of these?  Looking at the remnants of the old one still in situ, I couldn't work out how it was fitted.  Do I need to remove the door card first to get at fixings?  Haynes tells me nothing!
Re: Fitting L/H Rear Inner Door Scraper (5-door)
I have replaced a front door inner scraper. you would need to remove the door card the scraper could come off with the card if you lift the door card vertically or you could pull the card out of the scraper channel. The channel just slides onto a vertical section of the door. As I say this was a front door on a 3 door car but I can't see it being different.
Thanks, scs, that makes sense.  Just need to wait for the part to arrive!
