Topic: Rad support bushes... (Read 1781 times) previous topic - next topic
EDIT - Crossmember not rad support.
Anyone had any experience installing the oem style rubber ones? They seemed pretty flexible when I cut them out - are they easy to push in? Or is better to go poly here?
I have press and a vice.
Cheers
Matt
Re: Rad support bushes...
Absolute pain in the ass to get back in! Kept going off square and popping out.
I had to lube them up and use the press to get them back in.
I thought the same as you, the old ones were easy, but the new ones were a damn site stiffer.
As for poly vs rubber, I usually stick to rubber for them, as 9 times out of 10, I'll stick a solid front mount on.
If you leave the rear engine mounts stock along with the rubber crossmember bushes, that usually eliminates the vibration.
Cheers Monkey! Great I thought these might be a bugger :(
Got everything back from the powdercoaters now so I am on the rebuild phase.
Yeah, it's made even harder when you've got powder coat, as you're desperate not to chip/scratch it!
Plumbers silicone assembly grease sorted this one for me. That is after I warmed the bush in the oven and got to grips with a hot slippery bush.
Not an easy one.
Good tip with assembly grease. Did you still need to press in with a press? Assume we put bush in cross member first and then push in the bracket.
I didn’t use the press, used the kitchen breakfast bar and lots of twisting, pushing and swearing.
ohh interesting I'd rather do that as worried about damaging the fresh powdercoating. I will give it a try with some assembly grease. This is when you'll tell me you've got thumbs like King Kong and I fail miserably.
...I'm wondering if Phil has a vice on his breakfast bar..... :D
Would a metal or woodwork vice do the biz?
I've not had the "pleasure" of this task.
No vice, pushed them in by hand. I think I tilted them and twisted them?
Did you insert squidgy end first? Hmm I am struggling with hand, vice and press! It is too springy for the press.
I have out the others in the freezer whilst I play with just 1 to see if that helps
Solved - will upload pics when I am next on a computer.
I used an oil filter housing socket over the top of the squidy bit and pressed in with the vice.
After over an hour experimenting each bush went in under 2 mins. 4 done  4 left to do after dinner (mk3 Cross member)
Just had a look on the t'Internet to see what these look like.
There s a thread on Club GTI but the pics have gone AWOL!
Looks like you need to use a threaded bolt, nut some large washes and a piece of wood about 20-30mm with a hole the size of the bush so it can be forced through the xmember.
Lube the bush, then make a "sandwich".
Bolt > big washer > xmember > 20/30mm wood with hole > big washer > nut.
Might have problems getting a big enough 2nd washer so you could use a another thick piece of wood. Then tighten the bolt up.
Edit....another thought
If you had a big enough socket (I've inherited a few!) you could use that in lieu of the "holey" wood.
Edit2....I see you sussed it a different way, good stuff.
This is what i used in the end. It took a hour or so messing with different methods but this ended up taking approx 2 mins per bush
......and I was thinking you had to push it in as far as that big groove...was I wrong?
