Topic: Blue upholstery - rear bench covers  (Read 467 times) previous topic - next topic
I have a rear bench taken from a scrap car. I only need the metal frame for a project so the upholstery and if you want it foam is up for grabs.
Upholstery code DB
https://www.vwgolfmk2.co.uk/clubforum/index.php?topic=35.msg4703#msg4703
There is a rip on the top edge of the back rest, see last pic.
But otherwise seems in ok condition, just dirty.
Ideal for material patch up to fix fronts.
I'm asking £15 + post.
If you're able to collect from North Bristol I'll give you the foam. If you want postage I'll strip the material and fold it into a package and send via courier. The foam will then make it's way to land fill.
