Topic: Brake Compensator valve (Read 795 times) previous topic - next topic
Hi everyone. I have a 1986 Mk2 Gti and it recently failed its MOT due to a leaking brake compensator valve. I have struggled to find a replacement and wondered if anyone has any suggestions to help me to find one. Thanks…
Re: Brake Compensator valve
after doing a search, i've found a main-brake-cylinder on ebay.
is your part attached to it and is it the right one ?
i do not know what they mean with abs,
if it is for the building they say it for the 83-92 models
but also a abs (antilock-braking) version
or is abs just a part of a name, here ?
edit: maybe rather this one or the cheaper one, if at all.
 Would this be what you are looking for 357 612 151 VAG Brake Power Regulator?
Here you go...
https://www.heritagepartscentre.com/uk/357612151-brake-pressure-regulator.html
