Topic: MK3 5x100 rear discs and bearings (Read 454 times) previous topic - next topic
Nearly new rear discs, with bearings.
These are for 5x100 conversion which came on a rear beam I bought.
They have done very minimal miles, and although they look a bit crappy with surface they were nearly new, but the beam had been sat, stored outside for a little while.
Likewise the bearing were new and all parts are complete so there should be no issue reusing them.
Lips and hub centres were painted with satin black VHT, a few greasy marks from handling which would need cleaning and the surface rust would disappear with first use, or could be wire-wooled off to prevent contamination of new pads if you want to do things by the book.
Ideally for collection due to weight.
£15 ono - cash on pick up from North Bristol
If you need postage let me know, I'll get a quote.
