Topic: trim fixation (Read 513 times) previous topic - next topic
trim fixation
how do you tackle the common problem
of a loose side molding trim on the drivers door ?
in one case we bolted it on,
but this would make it necessary to get under the famous doorfoil,
just for removing it (and perhaps threading possible rust).
i bought new pins and grommets, but they do not grab tight enough:
please also let me know if there are any existing threads about the issue.
edit: do you see the image ? at times it says not found.
