Topic: blown head gasket causing coolant issues? (Read 283 times) previous topic - next topic
I have just recently acquired this golf and am trying to fix a coolant issue before I take it on more journeys. I'm thinking it could be the exhaust manifold/gasket or something else before I bother with replacing the head gasket?
  • replaced heater matrix as had steam come inside the car - new matrix installed
  • substantial loss of coolant
  • seems like it's boiling
  • have replaced the black with blue expansion cap
  • white exhaust smoke
  • coolant on top of manifold - is that a common thing?
  • steam/smoke coming from front of engine case (last video)
  • no mayonnaise on filler cap
  • did a dry compression test (right to left)1- 140 (9.82) 2- 120 (8.3) 3- 125 (8.64) 4- 80 (5.5) - (okay this is not great)
  • replaced water pump + new thermostat
I have taken it for hour drives recently but I'm reluctant till I sort these issues out first.
Engine bay
Video Preview Image
Exhaust
Video Preview Image
Smoke front of block
Video Preview Image
Any advice is welcome before I take off the head :)
Re: blown head gasket causing coolant issues?
Before you take the head off, do a block test.
They're cheap and will tell you straight away if you have issues in the head gasket.
I bought this one, worked a treat:
https://www.ebay.co.uk/itm/323563168415?chn=ps&norover=1&mkevt=1&mkrid=710-153316-527457-8&mkcid=2&itemid=323563168415&targetid=4584757337825780&device=c&mktype=&googleloc=&poi=&campaignid=555119508&mkgroupid=1298524385662659&rlsatarget=pla-4584757337825780&abcId=10039097&merchantid=87779&msclkid=e6c151140f60166565933635e8a54f3d
great idea thanks - have ordered one to try
well the test passed - didn't got yellow or green so that's good.
But while i'm at it replaced the following:
  • side and front cooling flanges as they were both leaking plus the o rings had perished
  • fan switch as found the current one was just loose and they're cheap
  • expansion tank as had a slight crack
  • bottom hose and the thin coolant hose
i'm just hoping this sorts out the majority of my coolant leaks and presume that i should not see any steam in the engine bay as the fan should cut in earlier....
