Topic: Ignition issue (Read 1316 times) previous topic - next topic
Ignition issue
Recently i've had a situation when starting the GTi where the key turns too far in the ignition & doesnt click back into the 1st position, resulting in the starter motor continuing to run after the engine has actually started. It needs a manual turn back every time.
Before i go buying parts, Is this likely to be a switch or barrel problem?
Thanks in advance
Re: Ignition issue
Thanks in advance
Its a 92 8v btw
Re: Ignition issue
I would say its the original judging by the key, which is pretty worn too.
Re: Ignition issue
Hi I've had the same problem, how did you resolve it Jenkaim?   did you buy a new ignition barrel?
Re: Ignition issue
to be honest i sold the car shortly after, so i didnt ever fix it!
Re: Ignition issue
If you remove the electrical switch from the back of the lock assembly does it still stick?
