Topic: Mk 2 16v restoration  (Read 7658 times) previous topic - next topic
Re: Mk 2 16v restoration
Reply #30
All your photo links from the past couple of posts seem to be broken
Try these, sorry about that.
16V GTI under restoration
Learning a lot  as I go along
Reply #31
Engine block painted. Oil pump arrived.. Ready to start assembly. Just mulling over the big end bolts. Genuine not available. Old genuine  or new third party bolts....
https://photos.app.goo.gl/n6sTEwBmRwYqr1Uv6
A prize for anyone that can tell me what is wrong in this photo.
https://photos.app.goo.gl/xUTcv54KxtnaBsew8
Reply #32
Fantastic work on the pistons! Great Transformation.
I replied to your other thread, but I'd go for ARP bolts, just for piece of mind.
BTW, stared at that photo of the head for longer than I should have and can't find the problem!
Reply #33
Thanks Whats ARP?
Reply #34
Well, the engine shop took out the exhaust manifold studs, presumably to help when they did their skim and valve seat stuff and a few helicoils. I was whiling away a few minutes happily sticking them all back in. When I'd finished  I noticed i'd put them back on the wrong (inlet) side - and that takes bolts!  And I've got some lovely new stainless ones for that. 20 more mins to take them out and put them in the right side!
Sorry, no prize!
Like I say, learning as I go along!
Reply #35
Oh Yeah! I completely missed that!!
ARP are the industry standard for upgraded engine bolts.
Their head bolts are very popular as you can re-use them.
https://arp-bolts.com/
American, but plenty of UK stockists.
Think I got mine off ebay.
Reply #36
Thank you. I see them. £147 a set.
I've got the Febi Bilsteins now. Aside from not being being re-usable, now I have them is there any real contraindication to using them, do you think?
Eddie
Reply #37
They are much stronger than standard, so if you were going or big power or particularly high revving, you;d certainly want a set.
I put them in the VR as we were charging it.
But Febi ones should be more than adequate for a normal rebuild.
Reply #38
Fair warning: If you get over-excited by VW Golf engines being worked on in machine shops, look away now.
Smallest overbore, just really to make the cylinders perfectly round again. https://photos.app.goo.gl/27FH2vKdCy7n354k9
Honing the new bores. https://photos.app.goo.gl/v52n383mZyDP4DXM9
Cutting the valves and seats.  https://photos.app.goo.gl/RS61ZnyiNs7pYqQo9
Planing the head.  https://photos.app.goo.gl/Mg7T5U4cj8VBT8Ns7
Time to reassemble the head. https://photos.app.goo.gl/cRhjzfD3xK1Ff2NP7
Head ready for another 125k miles!  Or maybe just to look at!    https://photos.app.goo.gl/LAYMZteKPgocahsA6
I warned you!
Work done by Sussex Engineering Supplies in Bognor. Lovely guys. Kelvin the mechanical magician.
Reply #39
Gosh those big end bolts were hard to find. Cancelled orders x 3! Finally secured them from GoSpares -  I hope, fingers crossed - they say they are in transit - woohoo!  Thanks  so much for the tip on this site.
Now,  does anyone know where I can get some door bins with speaker pods in them without paying the Earth...??
Reply #40
Hmm. Bit of a set back today on the big-end bolt front. I had asked the engineering shop if I should bring them in or have a go, and they said have a go.  The bolts are a very tight fit and I had to wind them in using a nut with increasing numbers of washers, with brass ones at the bottom end to stop them damaging the con-rod.
It looks like they've come out of the con-rod at a slight angle, as now I cant get the cap on.  Also, by eye it looks like the flat shell case may be distorted near the bolt exit, so I think I may have wrecked the con rod. Ah well, back to the engineers shop Monday for advice! Left the other three pistons well-alone!
On the plus side, the crankshaft went into the main bearings a treat, at least. Spins nicely free after torquing them up - and i didn't forget to put in the piston oil sprays first too!
Onwards and upwards
Reply #41
Got the new con rods and Pistons in and torqued up today, and put a few bits on the front of the engine.
Bottom end before Oil pump.  https://photos.app.goo.gl/UCMu19FtJg8uJWEe7
Lovely new pistons  https://photos.app.goo.gl/X3275zFkk6oCFY3x7. Took me a while to master the wind-up Snap-On spring compressor, then easy peasy.
Sump on - Oh, yes, bolts are all stainless. The wife insisted - at least I think that's what she said...  https://photos.app.goo.gl/JqnnexmTKx3KAhbx5
I don't know why I painted the breather red - just got in the queue when I was painting other stuff!
 https://photos.app.goo.gl/13yuS2j16wLN4oAt8
I'm having problems finding the right replacement crank end bolt.  Thats another thread!
Head next....
Reply #42
Found some lovely genuiine roof bars still in the box on eBay too, just like when I used to take the windsurfer down to the beach.  Had to buy 'em,.... Thinking  ahead maybe....
Reply #43
Had a day to do some more Golf today, weather, permissions, etc. all in place. Wohoo!!.
Drove down to the workshop to put the cylinder head on and get the cams and timing sorted, but you can only achieve so much when the timing chain turns out to be the wrong one! Got the head on and did some frittering about with sensors and swapping in stainless bolts and nuts etc., where I can, then came home and ordered a new timing chain.  Hopefully finish off the cam end and assemble the clutch end next time.
https://photos.app.goo.gl/C42aseExjoaxR4uu7
Reply #44
Looking good that and look forward to seeing the results post body shop. I'm just waiting to move house and will be following a similar journey to you - strip down and send the shell off to the bodyshop.
Your alloys will look nice and were an optional extra back in the day. I have teardrops on mine but will be getting a set of period BBS's too.
