Topic: GLi fan issure (Read 629 times) previous topic - next topic
GLi fan issure
does any one has a wiring diagram on the 2 speed fan with a/c PDF or what ever
problem with mine is the previous owner mechanic was having issue with the 2nd speed on the fan and decided to cut here and there. , now the wiring is all over the place and the 2nd speed does not work
....now i want to rewire it to the original anyone has a diagram of the system  thanks
Re: GLi fan issure
I don't have a diagram, but it is pretty straightforward to describe:
Essentially, it's a completely self contained system (doesn't go through the fuse box)
The power comes off the battery, down to the radiator switch.
That radiator switch has three contacts, one for power input, one for low speed and one for high.
The two speed wires goes straight to the fan, which has three contacts, two for the speed and one for the battery negative.
Hope this helps.
