Topic: Windows (Electric) (Read 959 times) previous topic - next topic
Windows (Electric)
Thanks to Eddypeck for his time and effort
https://youtu.be/Z6_RjZH0zUU
https://www.youtube.com/watch?v=gfxaPwpoHiU
having issues with sticky or slow window regulator, try these links.
I did pull mine apart further a few years ago on drivers side, this week will try do the passnger side see if can free it up, the powers reaching regular as lights dim... but not moving glass. damp has set in to motor i reckon.
UPDATE
Pulled door card off today, and managed to replace door lock mechanism, at the same time i did have a quick look at the window motor, i reached inside the runner and pulled/tugged on the wire cable and then loosened the securing bolts on the large runner  pressed the window button, magic works... so basically just needed a hand to move, i then added white grease to the PTFE runners, and went up/down a few times, happy with quick fix. took 30mins to do 2 jobs...happy
New Update
passenger door window winder, froze again so thats it....replacing with repro model.
jp group unit supplied, think was 40£  the power connection is 2 pins but different to oem, so i cut and joined up.
now running up and down again.
P.S DONT FOLLOW MY WIRING, IVE MANAGED TO PUT IN REVERSE, SO AT SOME POINT WILL HAVE TO RECRIMP.. HAHAHAHAHAHAHA
