Re: 1986 8v GTI restoration - You may recognise this one!
Power isn't everything, I still bet your 8v is every bit as fun to drive as mine - and probably far less likely to kill you!!!
I'd recommend going for a solid front engine mount and refreshing the rear ones.
You can get G60 rear mounts that will bolt up to your subframe and will wear a lot better than the standard 8v one.
Some people don't like a solid mount, but I've always used them with standard crossmember bushes and never had a problem.
