Topic: Con Rods (Read 1333 times) previous topic - next topic
Con Rods
Has anyone got any experience of MaXPeeding connecting rods in a 16v golf? I've busted mine and at £280 less discount to £200, these look like good value compared to standard VW at £500. Grateful for views, please?
16V GTI under restoration
Learning a lot  as I go along
Re: Con Rods
To finish this thread, on advice from a few of the wiser on this forum, I bought a set of  Pro-Race Engineering rods with ARP bolts. They look so good on new pistons and rings,  I'm kind of reluctant to hide them inside the engine!
Re: Con Rods
You can't say things like that and NOT post up a photo!
Re: Con Rods
sorry.
Brace yourself. Fair caution: Dont come crying if your keyboard wasnt drool-proof!
https://photos.app.goo.gl/6KRzm2QfPKTNT5ZE6
Even the bolts are gorgeous on their own!
https://photos.app.goo.gl/YxUfJYE94cSSj8f17
Re: Con Rods
Yeah, those are pretty sexy!
Re: Con Rods
What spec is the engine ? Personally id stick with the OEM rods.
Maxspeed racing sounds cheap
Re: Con Rods
Thanks Grey goose. Theres a story behind them.
The OE bolts were single use, so i needed to find more bolts. I was having trouble sourcing the right bolts but I found some Febi ones.  But they turned out to be a tad large and I'd wrecked a con-rod trying to fit them.
Disaster. .
So then I had a choice to try to source some second hand OE conrods and more expensive ARP bolts, or just to buy a matched balanced set of these lovely looking things. They were £400 with ARP bolts fitted, so not far off a replacement set of con rods and refitting  ARP bolts myself.
But to your question my engine is standard power, nowhere near what these are capable of handling.
Re: Con Rods
Ah i see, i spose you on the line of use used or pay a few quid more and have new, on the plus side the new rods 'should' be balanced which would save you a few hours of balancing the standard rods, one of mine was a fair bit heavier than the others which is normal due to mixed batches when the engines where built
Re: Con Rods
Yep  Engine is rebuilt now. Waiting for the shell to be finished and painted.  Hope it starts!
