Topic: AWD 20vT Mk2 GTi.  (Read 3853 times) previous topic - next topic
Re: AWD 20vT Mk2 GTi.
Any updates on this....? Looks mega! I am also planning to go down this route...
Yeah, there has been, quite a bit, I forgot I posted on here. I’ll do an update this evening :)
A TLDR;
I fully stripped, and raptor’d the whole underside.
Painted the engine bay.
I completed the work to the subframe and rear axle, sent everything off to powder coat.
Made a mount for the throttle pedal, and fitted an early fabless hydraulic clutch mount.
Painted the inside of the car and then added sound deadening before fitting the interior and dash wiring.
Fitted a K04 20v engine as I didn’t fancy the big turbo anymore. I did make an exhaust but that got nicked out of the car so I’ve got to do another.
Made a pair of rear shafts, and I’m yet to make the fronts.
Wiring for the engine is in, coolant hoses are done, interior 80% done, need to find some screws etc in the parts boxes. Brake lines are all done.
Front shafts and fuel are my next big jobs. Then build another exhaust and it should be able to go for an MOT.
And then paint! Obviously there’s loads of bits in between but that’s the main jist of it really.
Here’s how she currently sits.
