Topic: Wings (Read 797 times) previous topic - next topic
Wings
Front wings are bolt on.
When replacing them, if the ones being removed are original there will be a deep layer of sealant along the bask edge which will hide the last couple of bolts.
The wings are basically the same across all models (Golf/Jetta) for all years however there are some subtle differences between genuine original factory fitted early wings and the later spec ones.
The diagram below identifies some of the differences on later spec or reproduction wings.
Any reproduction wings bought now are based on the later spec. however depending on supplier you may find the repeater hole and holes for side trim need to be drilled if required.
