Central locking September 27, 2020, 10:26:20 AM I have an issue with the CL pump where it runs for 20 odd secs after the doors are open/locked. I've even swapped in a spare pump but the same happens, any ideas what theissue is here??
Re: Central locking Reply #1 – September 27, 2020, 10:34:32 AM This happens when you have a vacuum leak. Last Edit: September 27, 2020, 10:36:18 AM by sly_gti
Re: Central locking Reply #2 – September 27, 2020, 10:37:57 PM So is thats likely to be a leak in the pipework do you think?
Re: Central locking Reply #3 – September 28, 2020, 09:57:20 AM sounds that way. Most likely a split pipe where it goes through the boot hinge or the doors. 3 dr or 5 door? Obviously less doors to check on a 3 door. as it's only the passenger side, the drivers side is the master switch and that's electric.
Re: Central locking Reply #4 – September 28, 2020, 11:59:05 AM 5 door - cheers, I'll check out the pipe routing
Re: Central locking Reply #5 – September 28, 2020, 01:22:29 PM I wonder if listening for hissing would be enough to help you find it ?? good luck
