Topic: Gordon the Golf (8v GTi 1989) (Read 30556 times) previous topic - next topic
Reply #285
Sneak the sponges back in the kitchen, the Mrs will never know!
Reply #286
Polish splatter in there drives me nuts.  A squirt of quick detailer. slop it around with a brush, wipe off with a bit of wash up pad  :D .
Reply #287
Nope, that would be too much.  I'm allowed to plate parts in the kitchen and dry my polishing pads in the fan oven etc but those pads would be too much.
Reply #288
you are on slippery slope of not wanting to use the car unless the weather is perfect
Reply #289
I'm not sure I said that but I'm not going back through the thread to check, however I'm sure Gordon will not be getting wet too often.  The leisure and pleasure car that I bought to replace him 15 years ago has only had its wipers used twice, other than to shift insects.
What's at the bottom of the slippery slope; if I'm not there already?
Reply #290
Last thing yesterday my bodywork and paint luck ran out.  I've approached all of the regular rust spots expecting trouble.  Other than the issues I was aware of I've found nothing, no welding needed.
After the final polish of the bonnet I noticed a pin prick of a stone chip.  The paint around it appeared to be lifting and what looked like tin worm burrows were running left and right.  Out came the scalpel and I scraped away the paint to reveal rust.  It is treated and primed so will not get worse.  Look at this though in the middle of the leading edge of the bonnet:
Reply #291
What a bugger!
Could you fill it with paint and then flatten back to hide it?
Reply #292
What a bugger!
I'll look into hiding it, probably get a Facebook question up and see what the options are.  There are some 2K resins in paint code colours that you scrap in and flat back.  Ill finish the car and get it mobile. may need pro help.
Reply #293
I used one of the mobile paint people. They made a good job of it
Reply #294
The product description indicated that it may need reaming.  May was a bit of an understatement, a press is unlikely to have forced the pin in!
Bought a reamer and now have two hinges with tight fitting pins that can be pushed / forced in by hand.  I think that is correct.
I understand though that the top hinge is almost impossible to replace?
Reply #295
Hi Phil
Don't you have a local engineering workshop that can do it for you?
Reply #296
Hi Phil
Working on it; I could do with a local engineering shop,  Think I may have found one a few miles north at Leeming Bar.
Not needed for this job though, the £7 reamer delivered off eBay did the job
Reply #297
I thought the plating was over (until I start work on the Mini):
It is now.
Reply #298
Ok, so I see
4 boot strut points
4 number plate light fixing screws
4 boot plinth screws
But I can't work out what the two m5s are for.
Reply #299
The hatch lid wasn’t the only place I’d overlooked a couple of screws. They are door handle retaining screws.
