Topic: Gordon the Golf (8v GTi 1989) (Read 31406 times) previous topic - next topic
Reply #60
Pre-Thatcham alarm, not the original fitted to the car in 89 but an upgrade in the very early 90s.  Didn't work on the car but checked out fine on the bench so back to car to check all the alarm wiring.  Then if it still doesn't work I suspect a relay is sticking when under load of 4 indicator bulbs.  If that's the case back to the bench and time to get the soldering iron out.
Reply #61
Big day today - the rebuild has begun:
Reply #62
Next bit ready to go back on / in.  New flap foam, new seals, greased and new matrix so that bypass valves can be binned.
Reply #63
ICE; mid to late 80s style:
Reply #64
The original was full of oil; perhaps @Monkey you were right about the oil cooler.  Never noticed any emulsion under the cam cover though.  Anyway after considering dish washer tabs etc I discovered a new one was £9.99 delivered.  The pipe had 4 lots of heat shrink applied to stop it fraying further.  Not my proudest moment; I want the car back.
Reply #65
Can I
 I have been after the pink fleck hose for years ... please tell me it came with the reservoir for £10?.
Reply #66
Can I
No sorry, it's 30 odd years old; frayed at each end and and two points along its length I couldn't restore it nor replace it.  Decided to preserve it by applying heat shrink tube over the frayed sections.
Reply #69
Thanks I have often wondered why it’s pink but it’s definitely not faded red. I have a length of red and a length of plain black in reserve
Got some on order. Ill post a picture when fitted. I’m reasonably confident it will look OK.
If you decide to order some search for the correct size. The seller supplies this pipe in more than one size.
Reply #71
I've just noticed you've got all the wrong hose clips.
How can you sleep at night??! :o
Reply #72
A genuine VAG radiator.  I was surprised by that but couldn't find a date on it.
Reply #73
I was looking at this yesterday, https://www.hagerty.co.uk/valuation/tool/results/?y=1989&mk=Volkswagen&md=Golf&sm=GTI+Mk+II&b=Hatchback, and concluded that a Condition 1 MK2 could only exist if it had be bought new and stored for the purpose of showing 30 years later.  I put Gordon at 2.5
Reply #74
Jeeze! even condition 4 that puts my 91 at £7k.
