Topic: Polybush Top Mounts (Read 2207 times) previous topic - next topic
Re: Polybush Top Mounts
don't happen to have the part number for the larger ones do you?
I now know they have to be the 105mm ones, but the mind boggles at the shear amount of different ones available.
Wind back to reply#11.
All the details are in the Club GTI post.
1H0412341 is the part number of the spring plates.
B&B on ebay probably sell the other stuff. Found their service to be gr8 with super speedy delivery.
There''s different opinions on whether the car sits higher at the front. Mine was slightly "nose-up" to begin with so I put my eibach springs back on the front. Not sure if I will keep it like that tho!
Reply #18
Ok cheers, will go to VW and see what they have to say with that number
When you put it into Google, loads of different types appear,
Reply #19
Yes me too. Put it in eBay and I'm sure they are more expensive than the VW dealers. I put "vr6 front spring top" and just seen these although it doesn't say the diameter which I think needs to be 110mm.
FK 10mm lower
Good luck.
