Topic: Speedo woes (Read 1270 times) previous topic - next topic
Speedo woes
Hey guys
My Speedo doesn’t work. Any preliminary tests I should do? Common faults?
Cheers
Re: Speedo woes
It’s mechanical, cable driven so there’s not much to go wrong.
First question: has the instrument cluster been removed anytime recently? The Speedo cable sometimes doesn’t click back in to place properly and can pop off.
So there’s a drive in the gearbox. Which can drop off into the gearbox if you’re not careful when removing the speedo cable.
There’s the cable itself
and there’s the Speedo unit.
The Speedo unit doesn’t usually fail, but the cogs can wear and prevent the mileage counter form counting on. But in that instance Speedo still works.
Re: Speedo woes
Well I’ve just found that my Speedo cable had snapped. Quite bizzare really not sure how that happened. I guess I’ll have to be a new cable. I unclipped it from the dash cluster and then removed it from gearbox and a chunk of the cable inside just fell out
What is this drive you talking about and how would I know if it’s dropped into gearbox?
Re: Speedo woes
Job done 👍🏼
How do I upload a pic?
