Topic: Fusebox and relays CE2 (Read 17566 times) previous topic - next topic
For CE1 see here
CE2 Fusebox Fuses & Relays:
Fuse No. Description   Ampere Rating
1   Headlight, low beam, left   [10]
2   Headlight, low beam, right   [10]
3   Instrument panel lights, license plate lights   [10]
4   Glove compartment light, rear wiper   [15]
5   Wiper/washer   [15]
6   Fresh air blower, Air conditioning   [20]
7   Rear light, sidelight, right   [10]
8   Rear light, sidelight, left   [10]
9   Rear window defogger   [20]
10   Fog lights   [15]
11   Headlight, high beam, left, High beam indicator light   [10]
12   Headlight, high beam, right   [10]
13   Horn, Radiator cooling fan after run relay   [10]
14   Reverse lights, heated washer jets   [10]
15   Engine electronics, stabilizer valve, cold start valve   [10]
16   Instrument panel warning lights, MFA   [15]
17   Hazard switch, indicators   [10]
18   Fuel pump, oxygen sensor heater   [20]
19   Radiator cooling fan, air conditioning   [30]
20   Brake lights, cruise control   [10]
21   Interior lights, dash clocks, boot light, central locking   [15]
22   Radio, cigarette lighter   [10]
Relay No. Description
1   Air conditioning
2   Rear Wiper
3   ECU relay
4   Load reduction/x-over relay
5   Low coolant level control unit or Open
6   Indicators & emergency flashers
7   Headlight washers
8   Intermittent wipers
9   Seat belt/lights on warning relay
10   Fog lights
11   Horn
12   Fuel pump (fuel injection) Glow plugs (diesel)
13   Radiator cooling fan after run (except 16-valve) 2.0 16-valve: Starter interlock relay
14   Automatic gearbox, coolant temperature indicator, starter interlock relay (except 2.0 16-valve) 2.0 16-valve: Radiator cooling fan after run
15   ABS pump relay
16   ABS relay
17   Heated seat control unit, driver
18   Heated seat control unit, passenger, or Electric seat circuit breaker
19   Automatic gearbox
20   Open
21   Electric window relay, ABS hydraulic pump fuse
22   ABS valves fuse
23   Air conditioning, power seat fuse
24   Electric window fuse
CE2 Fusebox - Rear Connections
Connections and plugs on rear of fuse/relay panel:
A1 Yellow   8 pin   Headlight wiring harness
A2 Yellow   8 pin   Headlight wiring harness
B   Green   6 pin   Headlight washer wiring harness
C   Yellow   8 pin   Headlight or wiper motor wiring harness
D   Green   12 pin   Miscellaneous equipment, varies (A/C, A/T, heated seats, seat belt warning, etc.)
E   Green   5 pin   Instrument or brake light wiring harness
F   White   10 pin   Engine compartment/engine management, wiring harness, right side (position 10 open)
G1   White   12 pin   Engine compartment/engine management, right side
G2   White   12 pin   Engine compartment/engine management, right side (position 12 open)
H1   Red   10 pin   Steering column switch wiring harness
H2   Red   8 pin   Steering column switch wiring harness (position 8 open)
J   Red   10 pin   Steering column switch wiring harness
K   Black   12 pin   Rear wiring harness
L   Black   8 pin   Rear/Parking brake wiring harness (position 8 open)
M   Black   6 pin   Rear/fuel tank wiring harness
N   Green   6 pin   Air conditioning wiring harness
P   Blue   10 pin   Rear window defroster/fog light wiring harness
Q   Blue   6 pin   Fresh air blower fan wiring harness (position 10 open)
R   Blue   10 pin   Light switch wiring harness
S   White   5 pin   Engine compartment/wiper motor wiring harness, right side
T   Green   2 pin   Individual circuits
U1   Blue   14 pin   Instrument cluster wiring harness
U2   Blue   14 pin   Instrument cluster wiring harness
V   Green   4 pin   Steering column switch Multi-function indicator wiring harness
W Green   6 pin   Miscellaneous optional equipment, varies with vehicle type
X   Green   8 pin   Warning lamp wiring harness
Y   n/a   1 pin   4 single point connectors for terminal 30 circuit (some may be bridged with red connector)
Z1   n/a   1 pin   Single point connector
Z2   n/a   1 pin   Single point connector for terminal 31 circuit
30   n/a   1 pin   Single point connector for terminal 30 circuit (may be bridged to 30B with red connector)
30B   n/a   1 pin   Single point connector (may be bridged to 30 with red connector)
Taken from Rubjonny's original post is here:
http://www.clubgti.com/showthread.php?219775-Fusebox-FAQ
