Topic: Fusebox and relays CE1 (Read 7644 times) previous topic - next topic
For CE2 see here
CE1 Fusebox Fuses & Relays:
Fuse No. Description   [Ampere Rating]
1   Radiator cooling fan   [30]
2   Brake lights   [10]
3   Cigarette lighter, radio, dash clocks, interior lights, central locking   [15]
4   Hazard switch   [15]
5   Fuel pump (gasoline engines)   [15]
6   Open or fog lights   [10]
7   Rear lights, parking lights, side lights (left side)   [10]
8   Rear lights, parking lights, side lights (right side)   [10]
9   High beam, right, high beam indicator light   [10]
10   High beam, left   [10]
11   Windscreen wipers/washers   [15]
12   Rear wiper, heated seats, electric windows & mirrors   [15]
13   Heated rear screen   [15]
14   Heater blower, glove box light   [20]
15   Reverse lights, automatic transmission console light   [10]
16   Horn   [15]
17   Digifant ECU, 16v FEI module   [10]
18   Dual horn, coolant warning light control relay   [15]
19   Turn signals, brake warning light   [10]
20   Number plate lights, dash lighting on later models   [10]
21   Headlights (Low beam, left)   [10]
22   Headlights (Low beam, right)   [10]
Relay No. Description
1   Open or Digifant relay
2   Fuel pump (fuel injection) Glow plugs (diesel)
3   Seat belt warning
4   Shift light/MPG gauge relay (1985-1987)
5   A/C relay
6   Dual horns
7   Open or front fogs
8   Load reduction/x-over relay
9   Open
10   Windscreen wiper
11   Rear wiper
12   Indicators, hazard switch
13   Open or electric windows
14   Cooling fan after-run (except 16-valve)
15   Passive restraint (1988, 1989) or ABS/coolant temperature relay
16   Idle speed boost control relay (k-jet 8v)
17   A/C thermofuse or ABS
18   Coolant warning light control relay
19   Electric window relay
20   Heated seats (left)
21   Heated seats (right)
22   Oxygen sensor system power supply (US cars w/CIS) / Automatic transmission relay
23   Electric window thermofuse (30A)
24   Glow plug fuse (Diesel-50A)
CE1 Fusebox - Rear Connections
Connections and plugs on rear of fuse/relay panel:
A   Blue   28 pin   Instrument cluster wiring harness
B   Red   28 pin   Instrument cluster wiring harness (position 5 open)
C   Yellow   22 pin   Engine compartment/engine management, left side (position 10 open)
D   White   29 pin   Engine compartment/wiper motor wiring harness, right side (position 6. 10, 14, 18, 27, 28 open)
E   Black   18 pin   Rear wiring harness (position 17 open)
G   n/a   1 pin   10 individual circuits
H   Brown   6 pin   Air conditioning/coolant fan relay wiring harness
K   Neutral   5 pin   Seat belt warning system/coolant level wiring harness
L   Grey   4 pin   Horn wiring harness
L   Black   4 pin   Headlight/dimmer switch wiring harness
M   Black   2 pin   Steering column switch wiring harness
M   Black   2 pin   Headlight/dimmer switch wiring harness
N   Red   1 pin   Separately fused circuits (glow plug wiring harness, fuel injectors)
P   Red   7 pin   7 single point connectors for terminal 30 circuit
R   Green   2 pin   Open/ECU power supply relay
Taken from Rubjonny's original post is here:
http://www.clubgti.com/showthread.php?219775-Fusebox-FAQ
