Topic: Cope's GTI (Read 12880 times) previous topic - next topic
Re: Cope's GTI
Reply #90
That was a good catch with the tensioner, a couple of miles more could have spelled disaster!
I like the coolant vacuum thing, but how does it go about the thermostat?
Wouldn't that need to be open to get coolant everywhere?
Honestly I'm not sure, the tool expels all the air in the system so whether it can get past the other side of the thermostat I don't know. All I can say is that it worked a treat!
Re: Cope's GTI
Reply #91
I finally got round to designing and making some B pillar gussets for my cage.
Started out by trying to design something I liked the look of, I find it a challenge to make these look “right” and get the angles of the gussets correct.
Transferred what I had on paper into some steel.
I didn’t want to have to strip the interior so I used a large fire blanket on the floor and protected everything else with cardboard and tape.
Got them all welded in, took a few goes to get the welder set up right, but came out okay in the end.
This was then epoxy primed, and painted satin black. I’ve not got the car out of the garage yet so I don’t know how it all looks in the daylight, but so far I’m pretty happy :)
Re: Cope's GTI
Reply #92
Since the last update I’ve done loads of work to the Golf, and generally been using it loads, which has been really nice.
I’ll start with an evening track session at Cadwell Park. This was such a great way to spend an evening -  good weather, good mates.
The video below is one of my favourite track sessions I’ve ever had, and certainly the fastest I’ve ever gone around Cadwell! Chasing 2 race prepared Nova’s, our cars were very similar paced, so I had to work hard to get past.
https://www.youtube.com/watch?v=oP4SNnZM3o4&t=311s
At Cadwell I was trying to make the most of the 2 hours we had on track, so I was doing 35-45min sessions, I usually do around 20 min sessions. The Golf felt fantastic and handled the extended sessions well, I only came in because I was flagging and drip wet through!
The extended sessions did highlight one problem that you will see in the video – the brakes. When braking there was a crazy amount of shake coming through the steering wheel, to the point where I was struggling to keep hold of the wheel one handed while changing gear. I did some tests with a dial gauge when I got home, thinking it may have been warped discs, but the discs were dead true.
After doing some research and chatting to a few mates, we came to the conclusion it was pad deposits on the discs, I was apprehensive – could pad deposits really cause this much vibration? I cleaned up the discs with some scotch brite pads, and to my surprise completely cured the brake issue.
This did highlight one area for improvement though and that was cooling. I use the factory 16v brake ducts, which just vent to the wheel arch, so I decided to improve on that. Again I did my research, with the biggest takeaway being its best to duct air as close to the centre of the disc as possible, so the air can flow through the veins in the disc. With this in mind I started to modify the standard backing plates.
Holes were marked and cut, then a 2.5’ tube welded to the backing plates.
For anyone that has done this, you will know there is just no room for a 2.5’ duct, and there is literally only one way the tube will route without interference with the CV, driveshaft, track rod, suspension articulation, subframe to wishbone distance.
With the disc end sorted it was time to move onto the getting air from the front of the splitter. I’d decided not to bastardise the standard OE ducts, these seem to be worth a fortune now and really the shape didn’t lend itself well.
I started by remaking the ducts out of cardboard and tape.
Once happy I then wrapped the card in ali tape, to be used as a plug/mould for fibreglass.
It’s a messy process, but it came out really well once cleaned up.
I then used rivnuts in the metal front valance, to secure along with a cable tie.
I used 2 ply silicone ducting which should help with longevity.
Clearance is tight on lock, but there’s just enough room.
I’ve not done any heavy track work since, but I will report back once its been tested. I’ve also looking into the Porsche GT3 style ducting which clips onto the wishbone and directs air to the dics, which Might be the next option along with the ducting, but the ducting alone should be a big improvement.
Next update was some cosmetic upgrade to my steering wheel. I absolutely love this wheel, it’s a pretty  "uncommon"  Momo Jackie Stewart circa 1960. The leather was getting tired and my sweaty palms on track were not helping.
I decided to try and restore rather than retrim as I like the patina of an old wheel.
The original wheel:
I grabbed a kit from my local leather place for £50, which included a leather cleaner, sponges, primer, leather paint and a UV top coat.
I started by cleaning the leather and then sanding to scotch up the surface and level and of the bumps.
The finish result is really impressive! I just hope the finish lasts.
Next up was the Mk2 Golf Owners meet at Curborough, I went for the Sunday which was all VAG cars with my mate Nick in his Leon.
I started the morning off with road tyres on the rear and semi slicks on the front, this was to help the car rotate on this super tight track. Having an open diff doesn’t help here.
And rotate she did! Full opposite lock into the first corner with Ian onboard, we both were laughing the whole way round, and the rear came round on EVERY corner, much much fun, but not fast. So I swapped over to the semi slicks all round.
I’ll post a video up of my fastest time when I get it edited, but the car felt fast this year, the cage reinforcements made the chassis feel super tight. But the times don’t lie, how did I fair…
Well I’ll start with Nick, he managed a 27.7 lap, bagging him the fastest time of the day, taking home the silver ware. This is a properly serious time! And expertly driven by the man himself.
As the awards went on the last thing I thought was to hear my name called out. Despite trying to extract as much speed out of the 8v as possible, its just that, an 8v. It was never going to be a competitive car. As the famous John McGuiness says “you can only piss with the d*ick you’ve got”
To my surprise Matt called my name! with a 29.7 lap time. 4/10ths fastest than last year.
I was completely in shock and so chuffed! The award was a sponsors choice, given to the person achieving a decent time with the machinery under them.
Matt also wrote some very kind words in the awards posted on facebook.
Thanks buddy!
So that was that. The 2 Yorkshire lads bringing home the silverware!
Big thanks to the guys who organise this, its always so well run and the value for money is crazy for the amount of track time!
The last update is to the wheels (sorry this is a long post, ive been a busy boy! And I’ve actually skipped a lot of jobs out!)
I was never a fan of the dark wheels on a black car, so I decided to tackle them this last week, I spent a while deciding on colour, but finding the exact shade was so hard.
On a whim I decided to mix some base coats I had in the shed, I used some Arctic Silver from the E36 with some L041 Black from my Golf, in about an 80:20 ratio silver/black. And unbelievably this was the result.
I was over the moon with this, it had the perfect amount of goldy glitteryness, with silvery greyness. I also had about a litre of the stuff so Ideal for repaints/ touchups in the future.
The centres were masked up and prepped with some 800 scotch brite.
The inside of the wheel was also prepped. Very tedious work, but its worth the effort spending the time with prep.
Base coat
2k clear coat
Very very chuffed with the outcome.
And that’s it from me. I’ve got another evening session at Cadwell tomorrow night, so I’ll report back on the ducting to see if its cured. :)
Re: Cope's GTI
Reply #93
Great update again!
Good work with the brake discs, I used to encounter exactly the same thing.
Also, well deserved on the trophy, shame we didn't get a proper chance to catch up, but you looked like you were moving on well out there!
Re: Cope's GTI
Reply #94
It’s the start of Jan, and I see a post about a rather special event taking place.
The UK’s first ever night time track “day” at Anglesey ran by Mission Motorsport.
This was pretty major for me, it wasn’t a case of deciding if I should go, I HAD to do it!
I hadn’t even seen the Golf, let alone start it since September and with 2 weeks to go until the event, a new born baby and a displeased wife, I had my work cut out.
I would be joining Nige in his mk2, and after some confirmation from the organisers we found out there was no restriction on lighting. With Anglesey being totally unlit and a stones throw away (quite literally) from the edge of the Irish Sea, the challenge would be being able to see.
After having a mess around in photoshop I’d decided on a design/layout, and I wanted to go with yellow lighting – for those Nürburgring 24H vibes!
Amazon prime to the rescue, with 2 – 17” 250w LED light bars, some wiring, a switch and a couple of relays.
For me the design criteria had to be:
- Easily removable
- Hidden brackets when not installed
- Be brighter than the sun
With that in mind, here’s what I came up with. 2 rectangles were cut into the bumper, behind the number plate, to expose the metal bumper iron at the back.
Square box section was cut and angled, so it could be welded to the bumper iron, a cover plate was made with captive nuts, which would be welded to the box and fit flush to the bumper.
Once repeated on the other side, I started to make the brackets which would hold the light bars. The bracket can be bolted and unbolted with some m8 allen bolts.
I’d decided to stagger the 2 light bars, so they can be unbolted easier.
Once all the bracketry was made, I started on the wiring. I was worried about excess heat/ potential for fire from the draw of these LEDs. A chat to some friends and we figured out the draw was 21A, so the wiring was designed to take 25amps to be safe. A good friend drew me up a wiring diagram, which was super helpful. Essentially, they are wired as individual lights through 1 switch, which will make then as safe as they can be, rather than all the load going through one relay.
I was over the moon with how these turned out! And they were bright! - note the snow!!
After the lighting was done, it was 2 days before the event and I hadn't even started the car!
The next days I packed all my tools and spare tyres, and thankfully the Golf started first turn of the key! But… no time left to do any of the usual checks.
…just a 3.5 hour drive over to Anglesey and a track night to do!
I needn’t have feared, as always the Golf sailed over without an issue, I drive a 5 series estate daily and I have to say the Golf drives way, way better, you could easily daily it.
I met up with Nige, he had also been busy with the light bar!
The first session went out
The weather was super cold driving over, down to -7 on the motorway! Once on the island it warmed up to 2 degrees above. We were unsure of tyre choice so we had a wander down the pit lane, a few were on road tyres and a few on semi slicks. We decided to go with AR1’s, as it was cold but dry.
The first session was a complete sensory overload! But my god was it amazing!
The light bars were an absolute must!! And I’m so glad I went all in.
My mate Jim took this photo of me going past the pit wall, its got to be my favourite picture of my car and will be getting printed.
We did 4x30 min sessions on track all with different passengers, and each time we all had such a laugh. The experience was like nothing else! A big thanks to Mission Motorsport for putting the event on, it could have been absolute carnage but luckily everyone behaved and only a couple of yellow flags.
We stayed on the island that evening and headed home the next day.
It’s about 15 years since the Golf has seen a salty road, and it killed me inside!
YUCK!
Once home it was still -3 degrees, the hose pipe was frozen, but I wasn’t going to be beaten. An old coolant hose rigged up to the shower attached to the hose pipe, routed through the bathroom window and I managed to give the Golf a nice hot bath!
Back in the garage with the heater on… I can sleep now 
And that’s that for another adventure!
All I can say is it was incredible and something I’ll never forget.
I’ll be going through some onboard footage soon and I’ll make sure to post it here.
Until the next one
Re: Cope's GTI
Reply #95
So...need a good divorce lawyer, or did you grab some petrol station flowers on the way home??!
As usual, great write up and those brakes in that photo!!!
