Topic: Alarm choices (Read 3710 times) previous topic - next topic
Re: Alarm choices
The immobiliser with the proximity ring used to be my go-to immobilising device.
Very good, right up until the key ring breaks or you have a starting issue and can't trust it when diagnosing!
Nowadays, I'm going for a tracker and a hidden switch in the car.
Agreed, my point was if the insurance co. were insisting on some CAT measure then that would be my option. I doubt I'd fit one if I didn't already have one fitted. I did consider removing my alarm but it was a spider web of black wired heavily integrated into the loom. I didn't want to open that can of worms. I thought I'd best leave it, at least till it gives me any trouble.
Re: Alarm choices
I installed a Clifford alarm/immobiliser when I put my car back together, no dodgy scotch locks or tape. Used proper connectors and de-pinned the factory terminal blocks swapping out for alarm wires.
Most annoying thing is the battery drain. Keep thinking about a solar panel trickle charger.
Re: Alarm choices
Feel your pain, my blue one suffers from that, I've bought a ctek for the blue one now.
But the red one and Corrado will need a solar one.  Have you seen any decent ones?
Re: Alarm choices
Reply #18
big fan of fitting a hidden switch on the fuel pump, personally think alarms are a waste of time. The neighbours house alarm goes off all the time and nobody ever goes to check
Re: Alarm choices
Reply #19
I feel alarms are irrelevant when you talk about today's mk2 - in reality, do you really think someone is going to "hotwire" a mk2? I doubt it today, certainly true 10 yrs ago. In todays world it'll be put on a low loader and stripped for bits.
I would never recommend an alarm system for theft prevention on a mk2 - yes for general security ( window smashed, tilt sensor for wheels etc) but not for theft.
security on a Mk2 needs to be a Thatcham approved cat6 tracker, dont bother with the cheap ebay ones, you need confidence not doubt. To keep your own mind at bay add a cat2 touch imobaliser - we prefer the cobra as it a really neat install but to be fair choose whatever you fancy - as long as it's a certified cat2.
We been installing alarms for 20+ years, clifford approved, toad, cobra etc - the truth is they are all about the same, its all down to how good your installer is ;)
My Mk2 has a CAT2 touch imob. and a cat6 tracker. I have ever confidence that if someting did happen id get it back.
Re: Alarm choices
Reply #20
Have a look at thatcham approved trackers
Alarm/immobiliser approved and authorised to alert the police instantly incase of theft detection.
