Topic: Mk2 Golf Driver with 1.8T Conversion and Related Upgrades - £4950 (Read 1091 times) previous topic - next topic
Alpine White VW Golf Driver with 12 Months MOT and under 127k Miles.
Fitted with a 1.8T engine, gearbox, cable change shifter and hydraulic clutch.
G60 front brakes, Mk4 rear brakes, adjustable Spax coil overs and adjustable OBP brake bias valve.
It’s around 220bhp and due to the weight and gearing it is plenty fast and surprisingly economical.
It could have made a fraction more power from some more boost, but I didn’t want anything to compromise its reliability.
I have a few hundred miles on it now to make sure everything is right and there are no issues.
I’ve driven it on fast A Roads, twisty B Roads and sat in traffic jams and it behaves just as it should.
I have also done full VAGCOM logs to triple check everything engine and sensor wise is doing its job.
All serviceable items have been changed and everything has been done to last.
All parts listed ‘New’ were bought within the past few months and have covered less than 500 miles.
Engine / Transmission
AUM 1.8T Engine from a 136k Mile Audi TT
02J 5-Speed Gearbox and Shifter from the same Audi TT
K03S Turbo from a 112k Mile Octavia VRS
Corrado G60 Hydraulic Clutch
New Oil Pump and Pick-Up Pipe
New INA Cambelt kit with tensioner and water pump
New Borg and Beck VR6 Clutch Kit with G60 Flywheel
New Turbo Gaskets, Copper Washers and Banjo Bolts
New Manifold Gasket and Nuts
New Cam Cover Gasket and sump and oil filter housing re-sealed
New Bosch Spark plugs, colder grade and gapped properly
New Quantum Semi-Synth Oil
New Meyle Oil Filter
New Quantum Longlife Coolant
New Recirc Valve
New ASH Air Filter
New Toyosports Front Mount Intercooler
New Silicone Intercooler Hoses
OEM BAM Charge Pipe
New Forge Motorsport MAP Sensor Tube
New Bosch MAP Sensor
Creations Motorsport Silicone Turbo Intake Hose
New ASH Silicone Turbo Outlet Hose
New ASH Silicone Vacuum Hoses
Trackslag Ultimate Downpipe with new gasket
New 2.5” Side Exit Exhaust with 18” Long Stainless Silencer
New Radiator
New Radiator Fan Thermoswitch
New Electric Fan
New Thermostat
New Coolant Temp Sensor
New Heatshields around Steering UJ Boot and CV Boot
Custom Re-Mapped ECU
VAG Com Port for Diagnostics behind service book flap
Corrado 16v Fuel tank and Pump
New Fuel Filter
New Yuasa 063 battery
Hard plastic scuttle cover and GTI ECU cover
Chassis
Spax RSX Coilovers, Height and Damping Adjustable
New 16x7 Diamond of doom Captur Steel Wheels, powder coated in Signal Orange
New Genuine G60 Centre Caps and Wheel Bolt Covers
New 165/45r16 Nankang NS2 tyres
New Stainless Valves and Dust Caps
G60 Front hubs and 280mm Brakes
22mm Master Cylinder to match
New Mintex Front Discs and Pads
New OBP Adjustable Brake Bias Valve
Mk4 Rear Brakes
New Various Brake Pipes, Hoses and T-Pieces
New Rear Discs and Pads
New Handbrake Cables
New Brembo Brake and Clutch Fluid
Body / Interior
New Rear arch Spats
New Bosch Wiper Blades
New Number Plates (original dealer plates and key ring included)
New Lucas amber Side Repeaters
Undercoated for additional protection (not been welded)
Black Interior
New White wooden Steering Wheel
New White Nylon Gearknob
New Boost gauge in driver’s dash vent
Alpine CD / USB Head Unit
Alpine Front Door Speakers
New Horn
New Kit-Car Windscreen Washer Bag mounted in boot
Mechanically it’s 100% as you would expect, but then £4k worth of parts should have that effect.
The car itself is in good condition and the shell is solid on top and underneath.
I wanted to get it to a point where all it needed was a cosmetic freshen up and basic maintenance going forward, and it is definitely there now.
Bad Points
It's presentable, but would benefit from a handful of touch-ups due to a few minor age/carpark blemishes dotted around.
It does have a headlining fitted, but it has a missing section of cloth toward the back, doesn't really bother me but it's noteworthy.
This Mk2 has had a lot of time and money spent on it, so please keep any real low ball offers to yourself and no swaps or part exchanges sorry.
Payment by cleared bank transfer or cash only and collection will be from Hardwired Performance, BA4 4ND.
I am back working now so feel free to fire me a message on 07803 804 581 and I will answer any questions or can call you back whenever works for you.
Thanks for looking.
* Edited with fresh pictures, now that I've got some.
