Topic: CupraCraigs 20v Project (Read 8472 times) previous topic - next topic
Re: CupraCraigs 20v Project
Cracking project mate! Where did you get the bracket for the radiator fan, is it a custom effort?
Reply #19
Just another level with the wiring / braiding... amazing!
Reply #20
Tach adapter plumbed back in and running
IMG_20210104_214051 by Laxadams, on Flickr
Interested in the tach adapter, is it suitable for a v5?
I don't see why not, as long as your ECU has a tach signal output it just amplifies it for the dash.
Thanks, most of the engine loom and light loom has been done, so it looks really good and protects it well
Reply #22
That looks fantastic!
Reply #23
cheers dude, cant wait to drive it again. Hopefully i can comve visit you and pick your brains on Diffs!
I did a few more bits over the weekend.
I ran the lighting / fan power / altenator trigger wire looms through the chassis leg and connected them up
I had a look at the indicator loom and decided that i wanted to run it from inside the car, so rather than change it, i just made a brand new loom.
IMG_20210205_174119 by Laxadams, on Flickr
bit of a loom making selfie so some of you can put a face to the name:
IMG_20210205_164222 by Laxadams, on Flickr
i've also ordered a load of LED bulbs to replace the older style ones, so everything will be LED bar the headlight and fog light bulbs as having a strong white light from those i feel would look out of place
Reply #24
No worries, I may pick your brains on looms!
Reply #25
Not much visual progress but...i took the dials an did a refurbishment on them.
Guages are all working as expected.
New / additional temp sender ordered so both MFA and VDO's report on oil temp.
too cold on the weekend to work on it any more
IMG_20210214_132028 by Laxadams, on Flickr
Reply #26
They look great!
Did you paint them?
Reply #27
They look great!
Did you paint them?
Yeah just masked them up, rubbed down with some 400 grit and then primed and painted.
i have seen that you can buy brand new ones and just to add to the general clean look of the car i might buy a set. I could make up another loom for these and sell as a nice working set
Reply #28
Needed to escape into the garage last night, so wacked this new light loom up, braided it and made it detachable with an OEM connection.  that way if i ever have an issue with the LED bulb, i can just disconnect it and make changes simply. The led's are linked upto the lighting loom and are dimmable on the light switch
IMG_20210223_163144 by Laxadams, on Flickr
IMG_20210223_170640 by Laxadams, on Flickr
IMG_20210223_171826 by Laxadams, on Flickr
Reply #29
Is it wrong to get excited when you see such good wiring?
