Topic: Fuel Sender issues (Read 632 times) previous topic - next topic
Fuel Sender issues
Morning all,
had a crack at trying to solve the fuel gauge issue on mine - earthed the wiring at the fuel sender and the gauge flew up to max - so assume it is the sender unit causing the issue
following the hHaynes manual - the removal seems easy enough
also I am going to attempt this fix - Fuel Sender Fix
and finally if that doesnt work, would this part from VWH resolve the issues before getting the whole unit?
VDO Fuel Sender Universal
thanks
Re: Fuel Sender issues
Quick question on this
Would I need to drain the fuel tank for this?
