Topic: Headlights 1990 H plate Golf GTI MK2 16v (Read 807 times) previous topic - next topic
Just bought the above car and want to replace the headlight bulbs which are quite dim.
What is the brightest / best bulb I can fit without having to replace / upgrade the wiring.
Advice would be most welcome
Thanks
Re: Headlights 1990 H plate Golf GTI MK2 16v
Thanks
Great purchase!
Honestly, I've just upgraded mine and I would look for two things.
The uprated wiring loom and night breaker bulbs (others are available so you decide👍)
The loom puts 12v to bulbs instead of the 9v atm,
Also by the D/S headlight you'll find a yellow connector.. if it has a resisiter shaped like a packet of polos.. unclip it. You don't have to clip anything in ace but that also helps
I'll link my recent setup below
Uprated loom
Osram Night Breaker bulbs
Honestly the best update I've done so far.. makes the car usable in dark Belfast nights
The above is a great recommendation, though I wouldn't buy that particular loom.
H4 Booster kit
This is the same one, but only for £12.
Only thing is it's from China, so you'll have to wait a while for delivery.
