Topic: Red Rescued (Read 22162 times) previous topic - next topic
Re: Red Rescue
Reply #30
Great pics / progress... sort of near where you are with the block, so will be keeping a close eye on this, keep the camera handy!
(Did you look for the mystery 'rivet'?)
Re: Red Rescue
Reply #31
Oh crap! I completely forgot!
Re: Red Rescue
Reply #32
I forgot the rivet again!!
I've been on holiday for the last week, so I haven't had huge amounts of time or money to spend on the project.
That being said, the sand blaster was there and so was some worse for wear parts.
Won't bore you with them all, but here's a selection of before, during and after pics...
Untitled by Dave Ackerman, on Flickr
Really happy with the results, I just have so much more to do!!
Re: Red Rescue
Reply #33
Sandblasting's the doggies do-da's... very envious!
Re: Red Rescue
Reply #34
I bought a cabinet a couple of years back now, cost about £150 2nd hand and it completely destroys the compressed air supply, but it does a good job!
Re: Red Rescue
Reply #35
Sorry for anyone with slow internet connection, this is a big update!
Bit more blasting and cleaning was done, the water pump housing was especially bad!
I replaced the pump itself, wanted to make sure it had a metal impeller.
Thermostat was well past it though!
Next I turned my attention to the block, couple hours of prep and a couple coats of engine enamel later...
Also took my injectors to work where we have an ultrasonic cleaner!
Before:
And after
Finally, last night, I had an update from the painter!
Re: Red Rescue
Reply #37
Noticed you appear to have abandoned original heat shield on down pipe for exhaust wrap? My heat shield has disintegrated and thinking of doing same but not sure if this will mitigate heat soak on steering rubbers etc?
Re: Red Rescue
Reply #38
Yes, like yours mine was about to fall off.
So I've removed it and put the heat wrap to protect the rubber boots.
I'm trying to keep the car as original as possible, but couldn't do much about that.
Re: Red Rescue
Reply #40
I know this isn't an original feature but it is an early 90s addition. You have the same alarm as me mounted in the same position, or did have.  Is it going back in?
Great work.
Re: Red Rescue
Reply #41
Tornado red? Looks a bit dark
If you watch the video I posted on facebook, that looks mars red, so it evens out!
Re: Red Rescue
Reply #42
Great work.
Thanks.
No, it was very, very badly lashed in, also I didn't have any fobs for it.
So it (and the other two immobilisers) went in the bin.
Re: Red Rescue
Reply #43
Getting close now, bet you're well pleased with progress so far, and the paint looks outstanding.
Saw this on eBay - looks a neat solution... amongst others, they do a MK2 version also.
Damn you Mbps rich lot!
Re: Red Rescue
Reply #44
Thanks and yeah, I've actually got next week off work, so hopefully I can really crack on with it!
Oddly enough, I think my friend makes those.
Might tap him up for a couple.
