Topic: Indicator Fault 1987 1.3 (Read 462 times) previous topic - next topic
Hi everyone,
I'm a new mk2 owner.
When I use the indicator the interior light stays on and there is no light on the outside.
I will check the fuse but I'm getting confused on which fuses to check because for a 1987 they use the ce1 fuse box but alot of forums are saying the relay is 21.
Which fuses and relays do I need to check and is there anything else I can test to narrow down the issue?
