Topic: Need new headlining  (Read 3520 times) previous topic - next topic
Re: Need new headlining
Would be interested to know how well the material on these match the original material
You can buy the original material from VW heritage - maybe you can buy that abs get the company on eBay to use it
I actually used the heritage stuff on my blue golf, it's not original, but VERY close to it.
They've done a good job getting it reproduced.
The material on the one I've ordered is just straight black, but they give enough to recover the sunroof and sun blinds, so it should all blend in ok when it's done.
The original on my H-reg Driver is cream, and I think vinyl rather than brushed material.  Does anyone know a good source for this material, as the VW Heritage kit seems to be grey (perhaps GTI oriented?):  VW Heritage Headliner
Reply #18
That one from Heritage is the one I bought for my blue golf. It's nigh on identical to a black gti one.
My last one, I bought a whole headliner from headliner-world on ebay and it was an excellent fit:
https://www.ebay.co.uk/itm/184392433841?hash=item2aeea540b1:g:eOIAAOSwDDpdzDJ5
They say they do cream, might be worth a message?
Reply #19
Thanks, I've sent them a question about it.  Ideally, I'd like to get hold of something close to the original vinyl cloth, if possible.  I may end up getting the uncovered version and the cloth separately, if I can track it down.
Reply #20
@Monkey I've just received my headlining from headliner world, I'm curious how you redo the sun visors. Especially the hinge bit. Do you have any pictures of yours or any advice? Thanks
Reply #21
I've recently fitted one of these headliner world headlining and I pondered the same question.
I haven't done mine yet, and tbh not sure if I will bother. But if I were to do it I would cut the two sides to shape. Slightly oversize and sew them together along all but the top edge to create a bag. Then hand stitch the top edge, leaving the cut outs for the hinge and hook. Obviously any opening will need to be hemmed. Perhaps take to an upholsterer.
I can't imagine any attempt to just spray glue and cover would work very well.
Reply #22
There is a place called one up upholstery, I was going to ask them to do it as they have done them before and look very good.
I'm nowhere near skilled enough to do it myself!!
Reply #23
I’ve also fitted a reproduced headlining from headliner world, based on good feedback on this forum. Really pleased - it fits well, looks very close to original and appears to be well made.
Curious how people tackled the sunroof aperture though? (A small line is already cut out of the fabric, but you need  to cut the rest yourself.) I’m sure it’s not difficult but you only get one shot!
Is it a case of cutting it almost to size, but leaving a 1/2 cm of additional material to tuck into the sunroof seal?  And cutting in at each corner at 45 degrees?
