Re: Hello! / Current prices?
Reply #18 –
Having watched and seen the comments a lot depends on your own personal wishes, does it need to be oem? Bigger output engines are being fitted all the time and I guess it’s because they are no longer original the prices seem to be lower…. I don’t think you can be to picky in your wishes unless you get very lucky or have loads of time …I am not a fan of white cars but have had mine for 13 years , you will get an idea of value and there will be a car out there for your you at a price you are happy with …Rust is the thing to look out for , most oily bit problems are sortable ..
Mk2's seem to have turned a corner. A few years ago, you bolted another engine into it and it bumped the value by at least 1k.
I've done a fair few in my day, not to make money, just to make the car go faster, at the time I couldn't give the original engines away. But also, back then you could pick up a tidy mk2 for £500, that is very much not the case nowadays!
