Topic: Test your knowledge! (Read 33775 times) previous topic - next topic
Cleaning in and around the area of the car these come from otherwise I'd never have guessed - can you?
Re: Test your knowledge!
Don't recall seeing them on any of my cars
I'm thinking seat belt area?
Nope!
Do you have a size reference?
They go inside the rear beam and hold the nut for the bottom shock absorber?
Yep, that's them... well done!
Cheated a little and didn't include the nuts in the piccy, they're in the rust bath at the minute.
Saying as you've obviously looked at these, did you notice the nut is squeezed, making the threaded hole a slight oval?
Presumably intentional as mine fit back into the brackets a certain way because of it, a form of locking maybe?
Can't have been intended as permanent thing, shocks have the potential to be replaced.
'7Zap' doesn't show the brackets, just the nuts... wonder are they meant to be replaced / one use because of the initial (factory) squeezing?
That was fun, give me another one!
You've done well to still have them, they're nearly always missing.
Easy...
Is it French?
From the MK2... No markings on it.
That's why I remember them. The blue one I took apart was all original and never touched so they would have still been on there. I have a feeling it was around the rear end somewhere.
Is it part of the seats?
No
