Topic: Test your knowledge! (Read 33513 times) previous topic - next topic
Re: Test your knowledge!
Reply #105
Further back from PAS... Steering column?
I'll give you that one. It's the steering column to rack bolt!
Admittedly a bolt is a bit of a cheat, but it's the only bolt like that on the car.
Reply #107
Damn forgot about that, use to seeing the mk3 and  later type
Reply #108
How about this
Reply #109
Are we in the gearbox area again?
Reply #111
I'm thinking interior, maybe part of the sunroof assembly?
Reply #113
It's another one of those... I'm sure I've seen it items. I'm even pretty sure they were floating around in my tub of odds and sods left over after breaking one. I was also thinking interior, I'll need to rethink.
When you say exterior, does that include the engine bay area?
Reply #114
Fog light brackets?
Reply #117
I've a suspicion this'll be a short lived one... I've tried to picture it from a less obvious angle, but it's quite distinctive.
Reply #119
Indeed it is... 171 part number too, may be a hang over from the MK1.
