Topic: Test your knowledge! (Read 33510 times) previous topic - next topic
Re: Test your knowledge!
Reply #120
Another penalty kick, but I suppose it's only easy if you already know what it is!
Reply #122
Right again... if I'd stuck up the piccie of the rod from the gearbox here and not elsewhere would you have guessed it?
Reply #123
I didn't know that one
Reply #124
The starter bush?
I was going to ask how do you get the old one out, mines stuck fast.
Not sure if it's through age or they're pressed in - either way can't see how to get any purchase on it without risking damaging the aluminium of the bell housing in the process.
Reply #125
The starter bush?
I used a fat reverse thread removal tool thing. Got a pic somewhere, it made a mess and the bush came out in a few bits but worked.
I thought I was either that or the collar/spacer from seat belt mount. But they are more good and this looked brass.
Reply #126
Apparently there's a dedicated VW tool for removing these (VW 228 B) but they're a shocking amount of money and you'd need to be using it regularly to justify the cost.
Found this set up for less than £15 on Amazon - you can pay much, much more for the exact same thing elsewhere, so shop around.
Described as a blind hole bearing puller - does the same thing with the advantage of coming with additional sized tips.
I've probably the MK1 to do as well so went ahead and got it to see how it goes... the point the bush is sited looks very vulnerable to me, last thing I need is to break or crack the bell housing - will keep you posted.
Reply #127
Ignore the bolts just peeking into view...
Reply #128
Flywheel Spacer/Washer, goes between flywheel and crank.
Also, those bolts are clutch pressure plate bolts, 9mm if memory serves :))
Reply #129
Spit... 25 minutes, must be a record - now you're barred too.
Reply #130
Breather balance for the power steering boots?
Reply #131
Hi Phil,
Think you're replying to the wrong page, the power steering boot was a few days ago
 ;D
Ok, easier one...
1h6827584a_1_1 by Dave Ackerman, on Flickr
Reply #133
You're right!
As far as I know, this particular type is only on the tailgate plinth, as the others are smaller.
