Topic: Test your knowledge! (Read 42975 times) previous topic - next topic
Re: Test your knowledge!
Reply #166
Other (in)side of the bulkhead
Reply #167
Something to do with where the brake pedal connects to the rod that pushes into the servo then, although I have a Haynes on the shelf next to me and had a sneaky look. Nothing like that in the exploded diagram.
Let's face it, I don't know and if I get it it will be form guessing so I'll bow out and see if anyone else knows. After all it's 'test your knowledge' not 'guess from the clues'  :-)
Reply #168
Yeah, but guess from the clues is still kinda fun!
Reply #169
I believe it's the clip the holds the pedal to pedal box, stops the rod sliding out.
Bad explanation I know
Reply #171
What about this
Reply #173
It is not them,  but if anyone needs that panel I have 4 or 5
Reply #176
I'm not doing very well here I have not got one right yet.
Reply #177
In a sense this is a pretty obvious one as you could probably make a good guess at what it is even you'd never seen or noticed it before.
There's something about this particular one, but I'm not going to say what that is at this stage and risk giving it away to early!
The winner needs to give some specific detail, such as exact location etc. to win.
Reply #178
Gone very quiet... you're usually all over these!
Reply #179
Looks like it's the underside of the hedgehog heater on the inlet manifold of a carb engine.
 but missing the cable so possibly not that.
Also too flat for that
