Topic: Test your knowledge! (Read 33580 times) previous topic - next topic
Re: Test your knowledge!
Reply #255
Yes... but extra kudos for giving this particular versions location, there's a few different types (on my car at least).
Reply #256
I believe they are attached to the headlights to hold the corner of the grill tucked in
Reply #257
That's it...
Reply #258
Well done Sli.
I should have known this from modding the slam panel earlier this year!
Reply #259
Another penalty kick, reading a few recent posts suggests some of you should be familiar with what this is part of.
It would originally have been zinc plated, mines had a session in the phosphoric acid bath.
Reply #260
Does this go around the gear linkage to stop the ball dropping off, or something like that
Reply #261
Described as a 'guard plate', but yes, it clips on to the gear shift gubbins in the engine bay.
Reply #262
Both fitted in close proximity... may well be other similar items elsewhere on the car, maybe even doing a similar task, but these are specific to somewhere in particular.
Reply #263
That is definitely a 50p coin
Reply #264
Cut backs... would've been a £1 coin a few months ago!
Reply #265
the inserts in the fuel pump rubber mounts?
Reply #266
No... but they are very similar and in a roundabout way do the same job, just bigger.
Reply #267
Do they come in the gear linkage repair / bush kit.
Reply #268
Getting warm, I'll give it to you if you're specific.
Reply #269
they are the insets that sit in the cap in the remote box, and fasten to the same.
